Hollow Body Archtop Electric Guitar Kit, Basswood Body, Rosewood Fretboard, Chrome Hardware
SKU L5-RBRC-1
Original price $299 USD
$299 USD
$299 USD - $299 USD
Current price $299 USD
Build your own Hollow Archtop Body Guitar with Rosewood Fretboard using our DIY Guitar kits.
  • Laminated Mahogany has open grain that needs filling before finishing for a smooth result
  • Internal Support: Bridge block, Basswood
  • Binding: Multi-ply, Ivory
  • Shape: Semi-styled, 3+3
  • Bridge: Floating Bridge + Vibrato Tailpiece
  • Neck with dark fretboard (frets installed) and green abalone pearloid block inlays
  • 2x black-covered humbucker pickups in black mounting rings
  • Chrome adjustable bridge with six saddles
  • 2x chrome bridge posts with thumbwheels
  • Chrome hinged vibrato tailpiece with arm, tension spring and mounting screws
  • Pre-wired harness with four potentiometers and red, yellow and black hookup wire
  • Box-style 3-way toggle switch with black tip and chrome mounting plate
  • 4x chrome dome knobs
  • Output jack with nut and washer
  • Black triangular jack plate
  • Assorted chrome mounting screws and washers
  • Red felt washer
Unfortunately, Hollow Body Archtop Electric Guitar Kit, Basswood Body, Rosewood Fretboard, Chrome Hardware is out of stock.
