Blank Electric Guitar Kit, Mahogany Body, Mahogany Neck, Ebony Fretboard
SKU BLK-ST-A
$239.99 USD
$239.99 USD - $239.99 USD
Current price $239.99 USD
Build a fully custom instrument from the ground up with this ST-style blank guitar kit, crafted with a solid mahogany body and matching mahogany neck for rich sustain and warm tonal character. With no pre shaped contours or headstock profile, this kit gives you complete creative freedom to carve, sculpt, finish, and refine every detail by hand.
  • Scale Length: 648mm / 25.5″
  • Material: Ebony
  • Controls: 1 Volume, 2 Tone
  • Mahogany body blank, uncut, routed for the pickguard and bridge
  • Neck with dark fretboard, frets and dot inlays
  • Loaded black pickguard with three single-coil pickups, three knobs and a selector switch
  • Chrome tremolo bridge with six saddles
  • Tremolo sustain block
  • 3x tremolo springs
  • 2x long spring screws
  • Black tremolo cavity cover with six string slots
  • Chrome oval jack plate with output jack fitted
  • Tremolo arm
  • Coiled set of strings
  • String tree with washer
Blank Electric Guitar Kit, Mahogany Body, Mahogany Neck, Ebony Fretboard is on pre-order.
