Double-Cutaway Contoured Electric Guitar Kit, Alder Body, Quilted Maple Veneer, Dual Humbuckers
SKU ST-RAOC-1
Original price $259.99 USD
Current price $229.99 USD
$229.99 USD - $229.99 USD
Build a double-cutaway electric guitar with an alder body, a quilted maple top and two humbucking pickups. The body arrives with every cavity and hole already cut. Its flat top has a forearm contour on the edge and a belly cut on the back, so it sits comfortably against you while you play.
The maple neck has a dark skunk stripe down the back, an engineered rosewood fretboard, 22 stainless steel frets and a bone nut. Stainless steel frets stay smooth and wear far more slowly than standard nickel-silver frets. The headstock comes blank, with all six tuner holes already drilled in a single row, so you can keep its plain outline or cut your own shape. The neck attaches with four screws, with no gluing or clamping.
The black pearl pickguard comes with both pickups, one volume knob, two tone knobs and the 5-way switch already mounted. You solder the connections yourself, which is how you learn what each control does. A six-saddle tremolo bridge and chrome sealed tuners complete the hardware. The body and neck come unfinished, ready for whatever color you choose.
  • The headstock is a blank 6-in-line with its tuner holes already drilled, so you can finish it as it is or cut your own outline
  • Material: Alder (2-3 pc)
  • Top Contour: Flat top with forearm contour and belly cut
  • Material: Maple with skunk stripe
  • Middle Pickup: None
  • Pickguard: Black Pearloid
  • Guitar neck with engineered rosewood fretboard and white dot inlays
  • Black pearl pickguard fitted with two black open-coil humbuckers, three black skirted knobs and a blade switch
  • 6x chrome sealed tuners
  • 6x chrome tuner bushings
  • 6x chrome washers with mounting screws
  • Set of guitar strings
  • Black tremolo cavity cover plate with six string slots
  • Chrome neck plate
  • Black neck plate gasket
  • 4x neck mounting screws
  • 3x tremolo springs
  • Chrome tremolo arm
Double-Cutaway Contoured Electric Guitar Kit, Alder Body, Quilted Maple Veneer, Dual Humbuckers is in stock.
Find the diagram for your kit
