SKU BLK-ST-A
Original price $229 USD
Current price $199 USD
$199 USD - $199 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Dec 9 – Dec 23 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
  • Controls: 1 Volume, 2 Tone
  • 1x chrome neck plate
  • 4x neck mounting screws
  • 1x tremolo arm
  • 2x strap buttons
What is a blank kit?
The body is a solid block of wood, and you cut the outline yourself. The neck pocket and the tremolo route are already cut. The six tuner holes in the headstock are already drilled.
