WR Mahogany Bass Kit with Rosewood Fretboard
SKU WAR-RMRB-2
Current price $269.99 USD
$269.99 USD - $269.99 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Oct 2 – Oct 9 1–2 weeks from the date of your order. Ships to U.S. addresses only. Free Shipping
  • Number of Strings: 4
  • Scale Length: 864mm / 34″
  • Radius: 12" / 305mm
  • Number of Frets: 24 Extra Jumbo
  • Fret Size: Extra Jumbo
  • Nut Width: 39.88 mm (1.57 in)
  • Neck Pickup: P-style
  • Bridge Pickup: J-style
  • Controls: 2 Volume, 1 Tone, 3-Way switch
  • Bridge: Bass Bridge
  • Unfinished angular pointed body, front-routed for two pickups with a rear control channel
  • Neck with a dark fretboard, dot position markers and the nut fitted
  • 4x black bass tuners with bushings, washers and mounting screws
  • 1x black bar-style bass pickup with eight pole pieces and hookup wire
  • 1x black split bass pickup in two halves with four pole pieces each and hookup wire
  • 1x black four-saddle bass bridge
  • 3x black dome knobs
  • 1x pre-wired harness with potentiometers and wiring
  • 1x black square jack plate with the output jack fitted
  • 1x black neck plate with mounting screws
  • 1x black three-hole truss rod cover with two screws
  • 1x long black rear cavity cover strip with a screw hole at each end
  • 1x set of bass strings
  • 1x Allen wrench
  • 1x sealed bag of assorted screws
  • 1x group of loose black screws
WR Mahogany Bass Kit with Rosewood Fretboard is in stock.
Find the diagram for your kit
