Standard LP-style Guitar Kit with Mahogany Body and Neck
SKU LP-RMRC-947
Original price $239 USD
Current price $189 USD
$189 USD - $189 USD
  • Inlay Material: Ivory Plastic (ABS)
  • Nut: Ivory Plastic
  • Knobs: Black Plastic
  • Unfinished single-cutaway body with a carved top, routed for two humbuckers and a rear control cavity
  • Neck with dark fretboard, position markers and a drilled headstock
  • 6x chrome sealed tuners
  • 1x bag of chrome bushings and ferrules
  • 2x chrome covered humbuckers in black mounting rings
  • 1x pre-wired control harness with four potentiometers and hookup wire
  • 1x three-way toggle switch with black tip and a black washer ring
  • 4x black knobs with numerals
  • 1x chrome bridge with six adjustable saddles and mounting bracket
  • 2x chrome posts with knurled thumbwheels
  • Chrome washers and nuts
  • 1x black pickguard
  • 1x large black control cavity cover
  • 1x round black switch cavity cover
  • 1x black truss rod cover
  • 1x bag of assorted screws
  • 2x strap buttons
  • 1x Allen wrench and 1 truss rod wrench
Standard LP-style Guitar Kit with Mahogany Body and Neck is in stock.
It has a one-piece wraparound bridge with six saddles you can adjust. The strings attach to the bridge itself, so there is no separate tailpiece. There is no tremolo arm.
Does the body have binding?
No. The body and neck edges are plain wood, with no binding strip.
