SKU LJ1-RMMB-1226
Original price $249 USD
Current price $189 USD
$189 USD - $189 USD
If you are building your first electric guitar, this Junior style guitar kit is an ideal starting point. Its bolt on neck construction, uncomplicated hardware setup, and solid mahogany body provide an easy, low stress build experience while delivering reliable tone and playability.
  • Single-pickup wiring is about as simple as electronics get
  • Inlay Shape: Block
  • Nut: Ivory Plastic (ABS)
  • Neck Pickup: None
  • Controls: 1 Volume (wiring diagram)
  • Wiring Diagram: Single Humbucker, 1 Volume Only
  • Bridge: Wraparound (Bar)
  • Single-cutaway guitar body (unfinished)
  • Bolt-on guitar neck with dark fretboard and white rectangular block inlays
  • Black-covered pickup in a black mounting ring
  • Black wrap-around bridge with intonation screws
  • 2x black bridge posts
  • Black potentiometer with pre-soldered red and black wires, nut and washer
  • Black speed knob with white numerals
  • Output jack with mounting hardware
  • Black triangular jack plate
  • Round black cavity cover
  • Set of guitar strings
  • Black instrument cable with angled plug
Junior Single Cut Guitar Kit with Bolt-On Neck, Black Hardware is in stock.
1 humbucker, 1 volume
It has a one-piece wraparound bar bridge on two studs. The strings attach to the bar itself, so there is no separate tailpiece. There is no tremolo arm.
