SKU BLK-ST-B
Original price $229 USD
Current price $199 USD
$199 USD - $199 USD
  • Controls: 1 Volume, 2 Tone
  • 1x chrome neck plate
  • 4x neck mounting screws
  • 1x tremolo arm
  • 2x strap buttons
