SKU L3-RPRB-4831
Original price $299 USD
Current price $269 USD
$269 USD - $269 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Oct 27 – Nov 3 3–8 business days from the date of your order. Can take a little longer around holidays. Ships to U.S. addresses only. Free Shipping
Build your own classic blues inspired thin hollow body guitar. Featuring a laminated maple body with maple center block, set-in mahogany neck, Ebonized fretboard, and dual humbuckers for warm tone and dynamic response. Ideal for players seeking vintage character with modern reliability.
  • Material: Laminated Maple
  • Upper Bout: 310 mm
  • Waist: 248 mm
  • Lower Bout: 415 mm
  • Depth: 43.5 mm
  • Nut: Ivory Plastic (ABS)
  • Knobs: Black Plastic
  • Neck with dark fretboard, dot position markers, ivory binding and a drilled headstock
  • 1x large black pickguard
  • 1x black switch washer ring
  • 4x black knurled knobs
