Doublecut Junior Basswood Guitar Kit
SKU LPJ2-RPBC-1
Original price $279.99 USD
Current price $249.99 USD
$249.99 USD - $249.99 USD
Solid basswood body LP Junior style double-cut guitar kit with a maple neck and chrome hardware.
  • Bolt-on neck joint bolts straight on, so there is no gluing or clamping to get right, but the ash veneer is thin and easy to sand through, so use a light touch at the edges
  • Material: Basswood (2-3 pieces)
  • Top Veneer: Ash Veneer
  • Scale Length: 628mm (24.75″)
  • Inlay Shape: Block
  • Binding: Multi-ply Ivory
  • Neck Pickup: None
  • Bridge Pickup: P90
  • Double-cutaway body with an open-grain wood top, bolt-on neck pocket and a single pickup rout, unfinished
  • Neck with a black fretboard and pearl-look block inlays, bound headstock, unfinished
  • 6x chrome tuners with bushings and washers
  • 1x black single-coil pickup with pointed mounting ears and six exposed pole screws
  • Chrome wraparound bridge with six individual saddles
  • 2x chrome bridge posts with knurled anchor bushings
  • 2x black numbered speed knobs
  • Pre-wired harness with pot and coloured wire
  • Black rounded oblong cavity cover
  • Strap button with felt washer
  • Set of strings
  • Assorted screws
Unfortunately, Doublecut Junior Basswood Guitar Kit is out of stock.
1 P90, 1 volume, 1 tone
