Hollow Body Archtop Electric Guitar Kit, Mahogany Body, Ebony Fretboard
SKU E175-RMEG-3
Original price $319.99 USD
Current price $309.99 USD
$309.99 USD - $309.99 USD
  • Multi-ply binding must be masked carefully when finishing
  • Material: Mahogany Plywood
  • Cutaway: Single Florentine Style
  • Binding: Multi-ply Black
  • Binding: Single Black
  • Width at 5th Fret: 46 mm
  • Width at 9th Fret: 49 mm
  • Width at 12th Fret: 52 mm
  • Width at 22nd Fret: 56 mm
  • Material: Ebony
  • Inlay Material: Abalone
  • Controls: 2 Volume, 2 Tone, 3 Way Switch
  • Bridge: Tune-O-Matic w/ Trapeze
  • Knobs: Gold
  • Finish: Gold
  • Plastic Covers: Black
  • Hollow archtop guitar body with two f-holes and bound edges, unfinished
  • Guitar neck with dark fretboard and abalone block inlays
  • 2x gold-covered humbucker pickups in black mounting rings
  • 3-way toggle switch with black tip and gold nut
  • Gold tune-o-matic style bridge
  • 2x gold bridge posts with anchors
  • Gold trapeze tailpiece
  • 4x gold domed control knobs
  • Black archtop pickguard with gold mounting bracket
  • Set of strings
  • Assorted gold screws
  • Gold trim rings, hex nuts and washers
Hollow Body Archtop Electric Guitar Kit, Mahogany Body, Ebony Fretboard is on pre-order.
