Ash Body L1 Guitar Kit with Maple Veneer & Maple Fretboard
SKU LP-RMRC-398
Original price $279.99 USD
$279.99 USD
$279.99 USD - $279.99 USD
Current price $279.99 USD
Build your own Ash Body L1 Guitar Kit with Maple Veneer and Maple Fretboard using our DIY Guitar kits.
  • Material: Ash
  • Binding: Single Black
  • Top Veneer: Quilted Maple
  • Material: Maple with Skunk Stripe
  • Inlay Material: Abalone
  • Pickguard: Pearl White
  • Single-cutaway guitar body with a figured maple top veneer, routed for two humbuckers (unfinished)
  • Neck with light fretboard and large abalone block inlays
  • Black bridge with six adjustable saddles, plus posts and bushings
  • Black stop tailpiece with studs
  • 3-way toggle switch with nuts, washers and a black switch ring
  • 4x chrome dome knobs
  • Black square jack plate with output jack socket
  • Black neck plate with four mounting bolts
  • Black round rear cavity cover
  • 2x black strap buttons with black felt washers
  • Coiled string set
  • Assorted black screws
Unfortunately, Ash Body L1 Guitar Kit with Maple Veneer & Maple Fretboard is out of stock.
