Junior Single Cut Guitar Kit with Bolt-On Neck
SKU LJ1-RMMB-1226
Original price $249.99 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Oct 9 – Oct 23 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
If you are building your first electric guitar, this Junior style guitar kit is an ideal starting point. Its bolt on neck construction, uncomplicated hardware setup, and solid mahogany body provide an easy, low stress build experience while delivering reliable tone and playability.
  • Single-pickup wiring is about as simple as electronics get
  • Inlay Shape: Block
  • Nut: Ivory Plastic (ABS)
  • Neck Pickup: None
  • Controls: 1 Volume (wiring diagram)
  • Wiring Diagram: Single Humbucker, 1 Volume Only
  • Bridge: Wraparound
  • Finish: Black or Chrome (Have a preference? Email us right after you order. If we don't hear from you, we'll ship one of the two at random.)
  • Single-cutaway guitar body (unfinished)
  • Bolt-on guitar neck with dark fretboard and white rectangular block inlays
  • Black-covered pickup in a black mounting ring
  • Black wrap-around bridge with intonation screws
  • 2x black bridge posts
  • Black potentiometer with pre-soldered red and black wires, nut and washer
  • Black speed knob with white numerals
  • Output jack with mounting hardware
  • Black triangular jack plate
  • Round black cavity cover
  • Set of guitar strings
  • Black instrument cable with angled plug
Junior Single Cut Guitar Kit with Bolt-On Neck is in stock.
1 humbucker, 1 volume
