Double-Cutaway Contoured Electric Guitar Kit, Mahogany Body, Maple Neck, Rosewood Fretboard, 21 Frets
SKU ST-RXXA-209
Original price $239.99 USD
Current price $179.99 USD
$179.99 USD - $179.99 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Sep 17 – Sep 24 1–2 weeks from the date of your order. Ships to U.S. addresses only. Free Shipping
Build your own ST-style electric guitar with this high-quality DIY guitar kit, designed for smooth playability and classic tone. Featuring a solid two-piece mahogany body and a bolt-on maple neck with a 25.5” scale length, this kit delivers balanced resonance and comfortable feel. The rosewood fretboard with a 9.5” radius and white dot inlays ensures easy fretting across all 21 frets. Equipped with three single-coil pickups, a 5-way selector, and Vintage-style tremolo bridge, this kit is perfect for builders looking for iconic tones and customization freedom.
  • Bridge: Strat-Style Tremolo
  • Knobs: White
  • Neck with dark fingerboard, dot position markers and a drilled headstock
  • 1x chrome vibrato arm
  • 1x bag of assorted screws
Double-Cutaway Contoured Electric Guitar Kit, Mahogany Body, Maple Neck, Rosewood Fretboard, 21 Frets is in stock.
