Hollow Body Archtop Electric Guitar Kit, Single Venetian Cutaway, Gold Hardware
SKU L5-RPFG-468
Original price $329 USD
Current price $269 USD
$269 USD - $269 USD
Build your dream instrument with this Hollow Body DIY Guitar Kit, designed for builders who want a classic look with modern versatility. Featuring a laminated maple body with a solid maple center block, this venetian single-cutaway design delivers rich resonance and warm sustain, perfect for jazz, blues, and rock.
  • Material: Laminated Maple with Maple Center Block
  • Binding: Multi-ply Ivory
  • Upper Bout: 310 mm
  • Waist: 250 mm
  • Lower Bout: 415 mm
  • Depth: 83 mm
  • Material: Maple w/ a Skunk Stripe
  • Material: Pau Ferro
  • Shape: Classic Blues, 3+3
  • Nut: Black Plastic
  • Pickguard: Ivory
  • Knobs: Gold
  • Finish: Gold
  • Tremolo Arm: Tremolo
  • Single-cutaway hollow archtop guitar body with f-holes and bound edges (unfinished)
  • Guitar neck with abalone pearloid block inlays and bound fretboard (unfinished)
  • 6x gold sealed tuners with gold bushings and washers
  • 2x gold-covered humbucker pickups with black mounting rings
  • Gold bridge with six adjustable saddles on a wooden base
  • Gold vibrato tailpiece with hinged string bar
  • Gold vibrato arm with white tip
  • 4x gold dome knobs
  • Gold toggle switch with black tip
  • Wiring harness with red and black wires and potentiometers
  • Gold output jack ferrule and red felt washer
  • Ivory pickguard
  • Assorted gold and chrome mounting screws
  • Washers and nuts for the potentiometers and switch
  • Set of guitar strings
Hollow Body Archtop Electric Guitar Kit, Single Venetian Cutaway, Gold Hardware is in stock.
It has two humbuckers, one at the neck and one at the bridge.
