7 String Guitar Kits
A 7-string guitar gives you that extra low range that standard 6-string guitars cannot reach. The added seventh string, typically tuned to B below the low E, opens up deep, heavy riffs and extended chord voicings that define modern metal, djent, and progressive music.
Our 7-string guitar kits are designed for players who want extended range without buying a production guitar at a markup. Each kit comes with a wider neck and nut to accommodate the extra string, a body routed for high-output pickups, and hardware sized for 7-string spacing.
Building a 7-string kit is similar to a standard 6-string build with a few extra considerations. The wider neck needs careful setup to get the action even across all seven strings, and intonation takes a bit more patience. But if you have built a 6-string kit before, the skills transfer directly.
Every kit includes a pre-shaped body and neck, 7-string bridge, tuners, pickups, and all electronics. Pick your body style and start building.
Filters
7-string ICE-style Guitar Kit with Basswood Body and Maple Neck with Skunk Stripe
Current price $259.99 USD
$259.99 USD - $259.99 USD
Skill 5/10 Intermediate
Build your own 7-string ICE-style Guitar Kit with Basswood Body and Maple Neck with Skunk Stripe. Specifications Hand-Orientation: Righty Number...
JE-style guitar kit with 7-string Zebrawood Body
Current price $279.99 USD
$279.99 USD - $279.99 USD
Skill 6/10 Intermediate
Build your own 7-string DIY guitar using this JE-style guitar kit with 7-string Zebrawood (Engineered) body and ebony fretboard. Specifications ...
JBM 7 String Guitar Kit with Ebony Fretboard
Current price $289.99 USD
$289.99 USD - $289.99 USD
Skill 7/10 Intermediate
Build your own JBM 7 String Guitar with Ebony Fretboard using this DIY kit. Description Hand Orientation: Righty Headstock Shape: Styled ...
7-string Superstrat-style Basswood body Guitar Kit with Ebony Fretboard
$289.99 USD
Skill 4/10 Beginner
Build your own 7-string basswood body kit guitar with ebony fretboard and cool lightning bolt inlays. Specs Hand Orientation: Righty ...
7-string Mahogany JBM-style Guitar with Mahogany Neck and Rosewood Fretboard
$289.99 USD
Build your own 7-string Mahogany JBM-style Guitar with Mahogany Neck and Rosewood Fretboard using our DIY Guitar Kit. Description Hand O...
L1 Mahogany body 7-string Guitar Kit with Rosewood Fretboard
$299.99 USD
$299.99 USD - $299.99 USD
Current price $299.99 USD
Build your own 7-string DIY guitar using this DIY guitar kit with a mahogany body & set-in mahogany neck, rosewood fretboard, and trapezoid pea...
Hollow Body Archtop 7-String Electric Guitar Kit, Single Florentine Cutaway
Original price $329.99 USD
Skill 8/10 Advanced
Build your own 7-string hollow guitar kit with a mahogany body, ebony fretboard, F-holes, and Florentine-style single cutaway. Specifications Han...
Ash 7-string JS-style guitar kit with Flamed Maple Veneer
$299.99 USD
Featuring a right-handed, maple bolt-on neck, and a flamed maple top on a solid ash body, you'll not only satisfy your inner craftsman, but you'll ...
JS 7 String Guitar Kit
$399.99 USD
$399.99 USD - $399.99 USD
Current price $399.99 USD
Skill ?/10 Varies
Description Body Type: Solid Neck Shape: C-shaped Number of Frets: 22 Scale Length: 648mm Cutaways: Double Binding: None Pic...
G7-style Guitar Kit with 7-String Neck
$399.99 USD
Skill ?/10 Varies
Description Body type*: Solid Neck Shape*: C-shaped Frets*: 22 Scale*: 628mm Nut Width: 45mm; 1 13/16" Cutaways*: Double Pic...
JE 7 String Guitar Kit
$449.99 USD
$449.99 USD - $449.99 USD
Current price $449.99 USD
Skill ?/10 Varies
Description Body type: Solid Neck Shape: C-shaped Number of Frets: 24 Scale: 648mm Cutaways: Double Pickups: 2 Humbuckers Bridg...
JBM 7-String Guitar Kit
$449.99 USD
Skill ?/10 Varies
Build your own custom shop 7-string JBM-style guitar. Description Neck Joint: Bolt-on Neck Nut: Locking Nut Neck Shape: C-shaped No...
ICE 7 Guitar Kit
$449.99 USD
Skill ?/10 Varies
Unleash your creativity with the ICE 7 Guitar Kit! Build your dream guitar with customizable bodies, necks, timber, and hand-orientation options. E...
L-style 7 String Guitar Kit
$449.99 USD
Skill ?/10 Varies
L-style 7-string guitars expand your range when it comes to available chord voicings and tunings allowing you to play seriously down-tuned riffs wh...
Nut Width
A wider nut accommodates seven strings with comfortable spacing, so check that the nut width matches your hand size.
Scale Length
Longer scale lengths (26.5 inches or more) keep the low B string tight and defined, preventing a muddy tone.
Pickup Output
High-output humbuckers are essential for 7-string guitars to keep the low end focused under high gain.
Bridge Type
A fixed bridge is easier to set up and intonate on a 7-string. Tremolo bridges add complexity on extended-range instruments.
Is a 7-string guitar harder to build than a 6-string?
The build process is nearly identical. The main difference is setup: a 7-string needs more careful intonation and truss rod adjustment because of the wider neck and extra string tension. Budget extra time for the final setup.
What tuning does a 7-string guitar use?
Standard 7-string tuning is B-E-A-D-G-B-E, adding a low B below the standard 6-string tuning. Many players also drop the low B to A for even heavier tones.
Can I play regular 6-string songs on a 7-string?
Absolutely. The top six strings are tuned the same as a standard guitar. You just have an extra low string available when you want it. The wider neck takes a short adjustment period, but most players adapt within a week.
370+ Video Tutorials
