Ash 7-string JS-style guitar kit with Flamed Maple Veneer
SKU JS7-RSEB-257
$299.99 USD
$299.99 USD - $299.99 USD
Current price $299.99 USD
Featuring a right-handed, maple bolt-on neck, and a flamed maple top on a solid ash body, you'll not only satisfy your inner craftsman, but you'll also have a finely-tuned instrument, ready to fill the garage with some sweet, sweet music!
  • Number of Strings: 7
  • Bolt-on neck joint bolts straight on, so there is no gluing or clamping to get right, but the flamed Maple veneer is thin and easy to sand through, so use a light touch at the edges
  • Material: Ash (1 pc)
  • Top Veneer: Flamed Maple
  • Scale Length: 648mm
  • Material: Ebony
  • Inlay Material: Abalone
  • Bridge: Tune-O-Matic w/ String Thru Tailpiece
  • Ash guitar body with flamed maple veneer top (unfinished)
  • Guitar neck with dark fretboard and shell inlays
  • Black bridge with seven saddles
  • 2x black bridge posts with bushings
  • Pre-wired harness with potentiometer, 3-way toggle switch and coloured wire
  • Black dome knob
  • Black teardrop jack plate with output jack
  • Assorted black screws
Unfortunately, Ash 7-string JS-style guitar kit with Flamed Maple Veneer is out of stock.
