JBM 7 String Guitar Kit with Ebonized Fretboard
SKU JBM7-RZEB-725
Original price $299 USD
Current price $289 USD
$289 USD - $289 USD
Build your own JBM 7 String Guitar with Ebonized Fretboard using this DIY kit.
  • Number of Strings: 7
  • Floating tremolo needs its spring tension balanced against string tension before the intonation will settle
  • Number of Frets: 24
  • Inlay Shape: None
  • Shape: Styled
  • Nut: Black Locking Nut
  • Bridge: Locking Tremolo
  • Finish: Black Finish
  • Stripewood 7-string guitar body (unfinished)
  • Stripewood neck with ebonized fretboard, no inlays (unfinished)
  • 2x black humbucker pickups
  • Black rear cavity cover
  • Allen wrenches
Unfortunately, JBM 7 String Guitar Kit with Ebonized Fretboard is out of stock.
