SKU L3-RPRB-4831
Current price $269.99 USD
$269.99 USD - $269.99 USD
Build your own classic blues inspired thin hollow body guitar. Featuring a maple plywood body with maple center block, set-in mahogany neck, Ebony (Engineered) fretboard, and dual humbuckers for warm tone and dynamic response. Ideal for players seeking vintage character with modern reliability.
  • Maple Plywood is a closed-grain wood, so no grain filling is needed before finishing
  • Material: Maple Plywood
  • Upper Bout: 310mm
  • Waist: 248mm
  • Lower Bout: 415mm
  • Depth: 43.5mm
  • Scale Length: 24.75 inch (628mm)
  • Nut: Ivory Plastic (ABS)
  • Knobs: Black Plastic
  • Neck with dark fingerboard, dot position markers, ivory binding and a drilled headstock
  • 1x large black pickguard
  • 1x black switch washer ring
  • 4x black knurled knobs
