E25 Maple Thin Singlecut Hollow Body Guitar Kit w/ Ebony Fretboard, Gold Hardware, Diamond Inlays
SKU E25-RPBG-4812
Original price $319.99 USD
Current price $279.99 USD
$279.99 USD - $279.99 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Jun 26 – Jul 3 1–2 weeks from the date of your order. Ships to U.S. addresses only. Free Shipping
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Jul 17 – Jul 31 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
  • Orientation: Right-Hand
  • Scale Length: 628mm / 24.7"
Intermediate (5/10)
  • Material: Maple Plywood
  • Type: Hollow
  • Body Binding: White
  • Upper Bout: 310mm
  • Lower Bout: 415mm
  • Waist: 250mm
  • Body Depth: 43.5mm
  • Material: Maple (2 pcs)
  • Joint: Set-neck
  • Radius: 12"
  • Inlay Shape: Diamond
  • Binding: White
  • Shape: Blues Classic 3+3
  • Tuner Holes: 10mm
  • Nut Width: 42mm
  • Bridge Pickup: None
  • Output Jack: Side-mounted
  • Bridge: Gold Floating Archtop Bridge (Rosewood Base)
  • Tailpiece: Gold Trapeze
  • Tuners: Sealed Diecast Gold
  • Knobs: Black Speed Knobs
  • Gold trapeze tailpiece
  • 2x black speed knobs
  • Gold output jack
  • Steel strings
E25 Maple Thin Singlecut Hollow Body Guitar Kit w/ Ebony Fretboard, Gold Hardware, Diamond Inlays is in stock.
