SKU DVHB-RPRB-4237
$299.99 USD
$299.99 USD - $299.99 USD
Current price $299.99 USD
  • Number of Strings: 4
  • Material: Mahogany (2 pcs)
  • Scale Length: 775mm / 30 1/2" (short scale)
  • Radius: Standard
  • Number of Frets: 19
  • Fret Size: Standard
  • Shape: Blues Classic 2+2
  • Tuners: Closed, Chrome
  • 2x humbucker pickups
  • Output jack and jack plate
  • 4x chrome control knobs
