Tak's Tailless Guitar: 7.3 lb and a Shape No Store Sells
š” Recommended:Ā How do guitar electronics work?
Related: humbucker pickup guitar kits, P90 pickup guitar kits
š”Recommended:Ā How to fix electrical interferences
The neck position
The middle position
The bridge position
š” Recommended:Ā Guitar Kit Styles For Musical Genres
š” Recommended:Ā How High Should my Pickups be?
Are you unsure if you did your guitar right? Here's a great guide onĀ How to Perform a Complete Final Setup on Your Guitar
Want to hear the difference for yourself? Build a guitar with the pickup layout that suits your style. Browse our humbucker guitar kits, P90 pickup guitar kits, or explore the full range of DIY guitar kits to find the right setup for your sound.
Ready to build? Check out our custom guitar kits with pickup options.
Need a wiring diagram for your build? Browse every kit and pickup combo in our community: Find your wiring diagram ā
Simon S. cut his own body shape from a blank mahogany kit. Then he 3D printed a honeycomb pickguard to fit it and swapped four parts.
Vincent S. had a pale quilted maple top and chose not to stain it. He covered it edge to edge in tattoo-style stickers instead. Here is how he layered, masked and coated it, and what to test before you try it.
