SKU ST-RMPC-29
Original price $249 USD
Current price $199 USD
$199 USD - $199 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Dec 17 – Dec 31 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
  • Material: Mahogany (2 pcs)
  • Knobs: White Plastic
  • White plastic nut
  • String trees
  • Tremolo springs
  • Neck plate with screws
  • Output jack
  • Allen wrenches
Double-Cutaway Contoured Electric Guitar Kit, Mahogany Body, Maple Fretboard, Pre-Wired Electronics is on pre-order.
What is the fretboard like?
The fretboard is light maple with black dot markers.
