LP Style Electric Guitar with Mahogany Body, Ebony Fretboard & Humbuckers
SKU LP-RMEB-4826
Current price $239.99 USD
$239.99 USD - $239.99 USD
Built with a solid mahogany single-cut body and a sapele top veneer, this electric guitar kit offers classic looks and dependable performance. The ebony fretboard with pearl yellow trapezoid inlays sits on a bolt-on mahogany neck with an adjustable double-action truss rod. Dual humbuckers, black hardware, and a traditional Tune-O-Matic bridge ensure rich tone and stable tuning.
  • Bolt-on neck joint bolts straight on, so there is no gluing or clamping to get right, but the sapele veneer is thin and easy to sand through, so use a light touch at the edges
  • Binding: Multi-ply, White Outside
  • Top Veneer: Sapele (1-2mm in depth)
  • Binding: Single White
  • Inlay Material: Pearl Yellow
  • Nut: White, Plastic (ABS)
  • Knobs: Standard (as in product images)
  • Unfinished single-cutaway body with a bound edge, two routed pickup cavities and a routed neck pocket
  • Neck with dark fingerboard, bound edges, trapezoid position markers and a bound drilled headstock
  • 1x sealed bag with a black neck plate and long black neck screws
  • 1x sealed bag with a wiring harness of pots, capacitor and switch on yellow, red and black wires
  • 1x sealed bag with a white wrapped bundle and black hardware
  • 1x sealed bag with a black control cavity cover and screws
  • Several sealed bags of assorted black hardware and screws
LP Style Electric Guitar with Mahogany Body, Ebony Fretboard & Humbuckers is on pre-order.
