Semi-Hollow Double-Cutaway Electric Guitar Kit, Mahogany Body, Maple Fretboard
SKU E335-RMMB-5636
$299.99 USD
$299.99 USD - $299.99 USD
Current price $299.99 USD
  • Maple Plywood is a closed-grain wood, so no grain filling is needed before finishing
  • Material: Maple Plywood
  • Type: Semi-Hollow
  • Binding: Multi-ply, Black
  • Binding: Single Black
  • Bridge: Tune-O-Matic w/ Stopbar
  • Knobs: Black Plastic
  • Unfinished semi-hollow body with two f-holes
  • Neck with fretted fingerboard, block position markers and a drilled headstock
  • 2x black covered humbucker pickups
  • 1x black tune-o-matic style bridge with two posts and thumbwheels
  • 1x black stopbar tailpiece with two studs
  • 4x black ribbed speed knobs
  • 4x potentiometers with chrome nuts and washers
  • 1x three-way toggle switch with black tip
  • 1x output jack
  • 1x black pickguard with mounting bracket
  • 1x black jack plate
  • 1x black Allen wrench
  • 2x black strap buttons
  • Hookup wire and capacitors
Unfortunately, Semi-Hollow Double-Cutaway Electric Guitar Kit, Mahogany Body, Maple Fretboard is out of stock.
