Left-Handed Mahogany body EXP-style Guitar Kit
SKU EXP-LMEG-1
Original price $319.99 USD
$319.99 USD
$319.99 USD - $319.99 USD
Current price $319.99 USD
Build your own left-handed DIY guitar with a mahogany body and neck, ebony fretboard, and pearl white Trapezoid fretboard inlays kit.
  • Dexterity: Left-Handed
  • Material: Mahogany (1 pc)
  • Binding: Single Black
  • Material: Ebony
  • Controls: 1V, 1T, 3-Way Toggle
  • Knobs: Gold
  • Finish: Gold
  • Unfinished guitar body with bound edge
  • Unfinished neck with dark fretboard and pearl block inlays
  • String set
  • Gold output jack plate with jack
  • Pre-wired harness with potentiometers and wiring
  • Gold stop tailpiece
  • Gold bridge with individual saddles
  • 4x gold bridge and tailpiece posts and bushings
  • 2x gold dome control knobs
  • White pickguard
  • Black oval control-cavity cover plate
  • Assorted gold screws
Unfortunately, Left-Handed Mahogany body EXP-style Guitar Kit is out of stock.
Find the diagram for your kit
