Mahogany body EXP-style Guitar Kit, Ebony Fretboard
SKU EXP-RMEG-1
Original price $309.99 USD
Current price $299.99 USD
$299.99 USD - $299.99 USD
Build your own Mahogany body EXP-style Guitar with Ebony Fretboard, and Skunk Striped Maple Neck using our DIY Guitar Kits.
  • Nut: Black Plastic
  • Pickguard: Ivory
  • Knobs: Gold
  • Finish: Gold
  • Offset angular mahogany guitar body, unfinished, routed for two humbuckers
  • Neck with ebony fretboard and pearloid block inlays
  • Gold tune-o-matic style bridge with six adjustable saddles
  • Gold stop bar tailpiece
  • 4x gold posts and bushings for the bridge and tailpiece
  • 2x gold dome knobs
  • Output jack on a square gold jack plate
  • Ivory pickguard
  • Black rear cavity cover
  • 2x gold strap buttons with washers
  • Coil of wire
  • Truss rod wrench
Mahogany body EXP-style Guitar Kit, Ebony Fretboard is on pre-order.
