LP-Style Kit with P90 Pickups, Mahogany Body & Ebony Fretboard
SKU LP-RMRC-883
Current price $239.99 USD
$239.99 USD - $239.99 USD
Build your own classic rock machine with this LP-style DIY electric guitar kit. Designed for right-handed players, this kit delivers the timeless look and tone of a single-cut guitar while giving you the satisfaction of crafting it yourself.
Featuring a solid mahogany body with a smooth set-in mahogany neck, this kit offers warm sustain and rich resonance. The C-shaped neck and Ebony (Engineered) fretboard with trapezoid pearl-white inlays ensure a comfortable and stylish playing experience.
The electronics pack a punch with two ivory P90 soapbar single-coil pickups, wired through 2 volume controls, 2 tone controls, and a 3-way toggle switch, perfect for achieving everything from vintage blues to gritty rock tones.
Additional premium details include a bone nut, sealed die-cast tuners, Tune-O-Matic bridge with stopbar tailpiece, and double-action adjustable truss rod for long-lasting stability. With 22 frets, 24.75” scale length, and durable chrome hardware, this guitar kit is ready to be your next masterpiece.
Whether you’re a first-time builder or an experienced luthier, this DIY guitar kit gives you the freedom to customize the finish, setup, and final touches to create a one-of-a-kind instrument.
  • Set-in neck has to be aligned and glued before finishing, and that joint is what most affects intonation
  • Tune-o-matic bridge and stopbar tailpiece set intonation quickly once the posts are seated
  • Shape: Classic blues, no binding
  • Neck Pickup: P90 soapbars (ivory, single-coil)
  • Bridge Pickup: P90 soapbars (ivory, single-coil)
  • Controls: 2 Volume, 2 Tone, 3-way toggle
  • Wiring Diagram: 2x P90, 2 Volume, 2 Tone, 3-Way Switch
  • Knobs: Gold plastic top-hat style
  • Strings: Standard Steel
  • Finish: Chrome set (tuners, bridge, tailpiece, etc.)
  • Mahogany single-cutaway guitar body (unfinished)
  • Guitar neck with ebony fretboard and pearl trapezoid inlays (unfinished)
  • 2x ivory P90 soapbar pickups
  • Chrome tune-o-matic style bridge with posts and thumbwheels
  • Chrome stopbar tailpiece with studs
  • 4x gold top-hat knobs
  • 3-way toggle switch with cream tip
  • Output jack with wiring
  • Black rear control cavity cover and round switch cover
  • Cream truss rod cover
  • Set of guitar strings
LP-Style Kit with P90 Pickups, Mahogany Body & Ebony Fretboard is in stock.
