7 String Guitar Kits
Chances are you've thought about creating your own guitar at some point. There's nothing quite as rewarding as building something with your own hands and seeing it come to life.
If 6 strings are not enough, build your own 7 string guitar with the help of our DIY kits. All you need is a basic tool kit, a little time, and some patience. We've made it as easy as possible for you to build your own custom 7 string guitar. Guitar Kit World will provide you with everything you need to build your very own high-quality 7 string electric guitar.
Build your DIY 7 String Guitar with our available kits. Get started now:
  • 7-string RG style Basswood body Guitar Kit with Ebony Fretboard
    (0)
    Guitar Kit World Originals
    Current price $219.99 USD
    $219.99 USD - $219.99 USD
    Build your own 7-string basswood body kit guitar with ebony fretboard and cool lightning bolt inlays ⚡ Specifications Hand Orientation: Righty H...
    Save $70.00 USD Save $0.00 USD
  • Mahogany Body G style 7-string Guitar Kit with Ebony Fretboard
    (1)
    Current price $279.99 USD
    $279.99 USD - $279.99 USD
    Build your own 7-string Mahogany Body DIY guitar using this DIY Guitar Kit. Specifications Hand Orientation: Righty Headstock Shape: Styled Neck...
    Save $10.00 USD Save $0.00 USD
  • JE-style guitar kit with 7-string Engineered Zebrawood Body
    (0)
    Build your own 7-string DIY guitar using this JE-style guitar kit with 7-string engineered Zebrawood body and ebony fretboard. Specifications Hand...
  • JBM 7 String Guitar Kit with Ebony Fretboard
    (0)
    Current price $289.99 USD
    $289.99 USD - $289.99 USD
    Build your own JBM 7 String Guitar with Ebony Fretboard using this DIY kit.  Description Hand Orientation: Righty Headstock Shape: Styled Neck Joi...
  • Ash 7-string JS-style guitar kit with Flamed Maple Veneer
    (1)
    Featuring a right-handed, maple bolt-on neck, and a flamed maple top on a solid ash body, you'll not only satisfy your inner craftsman, but you'll ...
  • L1 Mahogany body 7-string Guitar Kit with Rosewood Fretboard
    (3)
    $299.99 USD
    $299.99 USD - $299.99 USD
    Current price $299.99 USD
    Build your own 7-string DIY guitar using this DIY guitar kit with a mahogany body & set-in mahogany neck, rosewood fretboard, and trapezoid pea...
    $299.99 USD
  • Hollow Body 7-String Guitar Kit with Ebony Fretboard
    (2)
    Original price $329.99 USD
    Current price $319.99 USD
    $319.99 USD - $319.99 USD
    Build your own 7-string hollow guitar kit with a mahogany body, ebony fretboard, F-holes, and Florentine-style single cutaway. Specifications Ha...
  • JS 7 String Guitar Kit
    (0)
    Custom Shop Kit
    $399.99 USD
    $399.99 USD - $399.99 USD
    Current price $399.99 USD
    Description Body Type: Solid Neck Shape: C-shaped Number of Frets: 22 Scale Length: 648mm Cutaways: Double Binding: None Pickups: 2 Humbuckers B...
    $399.99 USD
  • G7-style Guitar Kit with 7-String Neck
    (0)
    Custom Shop Kit
    $399.99 USD
    Description Body type*: Solid Neck Shape*: C-shaped Frets*: 22 Scale*: 628mm Nut Width: 45mm; 1 13/16" Cutaways*: Double Pickups*: 2 Humbuckers ...
    $399.99 USD
  • JE 7 String Guitar Kit
    (0)
    Custom Shop Kit
    $449.99 USD
    $449.99 USD - $449.99 USD
    Current price $449.99 USD
    Description Body type: Solid Neck Shape: C-shaped Number of Frets: 24 Scale: 648mm Cutaways: Double Pickups: 2 Humbuckers Bridge: Double Locking ...
    $449.99 USD
    (0)
    Custom Shop Kit
    $449.99 USD
    Description Body type*: Solid Neck Shape*: C-shaped Frets*: 24 Scale*: 648mm Cutaways*: Double Binding: None Pickups*: 2 Humbuckers Bridge*: Doub...
    $449.99 USD
  • ICE 7 Guitar Kit
    (0)
    Custom Shop Kit
    $449.99 USD
    Description KIT Name: ICE 7 Guitar Kit Body type*: Solid Neck Joint: Bolt-On Neck Shape: C-shaped No. Frets: 22 Scale*: 628mm Cutaways*: Single P...
    $449.99 USD
  • L-style 7 String Guitar Kit
    (0)
    Custom Shop Kit
    $449.99 USD
    L-style 7-string guitars expand your range when it comes to available chord voicings and tunings allowing you to play seriously down-tuned riffs wh...
    $449.99 USD
