Hollow Body Archtop Electric Guitar Kit, Maple Body, Ebony Fretboard, Dual Humbuckers
SKU E75-RPBG-4812
$329.99 USD
$329.99 USD - $329.99 USD
Current price $329.99 USD
  • Maple Plywood is a closed-grain wood, so no grain filling is needed before finishing
  • Material: Maple Plywood
  • Binding: Single White
  • Upper Bout: 275 mm
  • Waist: 235 mm
  • Lower Bout: 384 mm
  • Depth: 83 mm
  • Width at 5th Fret: 46mm
  • Width at 9th Fret: 49mm
  • Width at 12th Fret: 52mM
  • Width at 22nd Fret: 56mm
  • Inlay Shape: Diamond
  • Tuners: Sealed
  • Unfinished hollow archtop body with two f-holes, two routed pickup cavities and a routed neck pocket
  • Neck with dark fingerboard, split-block position markers and a drilled headstock
  • 1x black-covered humbucker with lead wire
  • 1x humbucker with chrome centre bar and black surround
  • 1x large black pickguard
  • 1x small black bell-shaped cover plate with two screws
  • 1x wiring harness with pots, capacitors and chrome output jack
  • 1x chrome toggle switch with chrome tip, nut and washer
  • 1x chrome bridge with six adjustable saddles, two posts and thumbwheels
  • 1x chrome bar tailpiece with two mounting studs
  • 4x black knurled knobs
  • 1x bag of chrome mounting screws
Hollow Body Archtop Electric Guitar Kit, Maple Body, Ebony Fretboard, Dual Humbuckers is on pre-order.
