SKU E25-RPBG-4812
Original price $319.99 USD
Current price $279.99 USD
$279.99 USD - $279.99 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Oct 7 – Oct 14 1–2 weeks from the date of your order. Ships to U.S. addresses only. Free Shipping
A thin singlecut hollow body kit with a Florentine cutaway and a slim 43.5mm body depth. Lighter and more responsive than deeper hollow builds, this kit delivers classic archtop character with faster note response and improved feedback control. The laminated maple body with elegant f-holes, Ebony (Engineered) fretboard with diamond inlays, and full gold hardware make it an ideal build for jazz, blues, soul, and clean melodic playing styles.
  • Material: Laminated Maple
  • Binding: White
  • Body Depth: 43.5mm
  • Upper Bout: 310mm
  • Waist: 250mm
  • Lower Bout: 415mm
  • Joint: Set-neck
  • Scale Length: 628mm / 24.7"
  • Inlay Shape: Diamond
  • Binding: White
  • Nut Width: 42mm
  • Tuner Holes: 10mm
  • Bridge Pickup: None
  • Tailpiece: Gold Trapeze
  • Tuners: Sealed Diecast Gold
  • Knobs: Black Speed Knobs
  • Finish: Gold
  • Gold trapeze tailpiece
  • 2x black speed knobs
  • Gold output jack
  • Steel strings
1 humbucker, 1 volume, 1 tone
