SKU DVHB-RPRB-4237
$299.99 USD
$299.99 USD - $299.99 USD
Current price $299.99 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Sep 14 – Sep 21 1–2 weeks from the date of your order. Ships to U.S. addresses only. Free Shipping
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Oct 5 – Oct 19 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
  • Number of Strings: 4
  • Material: Mahogany (2 pcs)
  • Scale Length: 775mm / 30 1/2" (short scale)
  • Radius: Standard
  • Number of Frets: 19
  • Fret Size: Standard
  • Shape: Blues Classic 2+2
  • Tuners: Closed, Chrome
  • 2x humbucker pickups
  • Output jack and jack plate
  • 4x chrome control knobs
