Build your own acoustic electric guitar with this semi-hollow ST-style DIY guitar kit, designed for builders who want acoustic warmth, electric versatility, and full customization. This kit features a semi-hollow body with a center block, offering enhanced sustain and feedback control while preserving natural acoustic resonance.
The body is crafted from basswood and topped with a flamed maple veneer, finished with elegant ivory binding for a classic look. A bolt-on maple neck with a comfortable C-shaped profile and rosewood fretboard provides familiar playability, while the blank headstock allows you to shape and personalize your own design.
This acoustic electric guitar kit comes equipped with a piezo pickup system and a built-in 4-band equalizer with master volume, giving you precise control over your tone when plugged in. The electronics are fully pre-wired and plug-and-play, requiring no soldering during installation. A traditional acoustic-style bridge with pins ensures reliable string seating and a familiar feel. A 9-volt battery is required to power the EQ and is not included.
Designed for experienced builders or confident DIY enthusiasts, this kit is ideal for custom finishes, unique builds, and players looking for a versatile acoustic electric platform. Whether you plan to stain, paint, or oil finish your guitar, this kit ships unfinished so you have complete control over the final result.
This acoustic electric semi-hollow ST-style guitar kit is a great choice for players seeking a hands-on build experience and a playable, stage-ready instrument with distinctive tone and style.
Acoustic Electric Guitar Kit With Equalizer Assembly Manual
- Hand Orientation: Right-Hand
- Headstock Shape: Blank
- Neck Joint: Bolt-on
- Nut Width: 42 mm
- Neck Material: Maple
- Headstock Binding: None
- Neck Nut Material: Plastic
- Fretboard Material: Rosewood
- Neck Binding: None
- Fretboard Inlays: Dots, White
- Neck Shape: C-shaped
- No. Frets: 22
- Scale Length: 648mm, 25.5"
- Body type: Semi-Hollow with Center Block
- Body Material: Basswood
- Body Top Veneer: Flamed Maple
- Body Binding: Ivory
- Pickups: Acoustic Equalizer
- Electronics: 1 Volume, 4 Band Equalizer (9-volt battery not included)
- Bridge: Acoustic Style, With Pins
- Pickguard: None
- Cavity Covers: None
- Hardware Set: Chrome Finish
- Tone & Volume Knobs: Black Plastic
- String: Steel
- Machine Heads: Closed
- Truss Rod: 2-Way Adjustable
