Double-Cutaway Contoured Electric Guitar Kit, Engineered Zebrawood Body, Rosewood Fretboard, Black Hardware
SKU ST-RZEB-1
$279.99 USD
$279.99 USD - $279.99 USD
Current price $279.99 USD
Ready to add a new badge to your DIY hall of fame? Our Zebrawood ST style body Guitar kit with an Rosewood fretboard is ready to roll with you. Put your craftsmanship to the test and create your very own right-handed guitar, featuring a bolt-on neck and 22 frets. It's practically a symphony of wood, eagerly waiting to play your tune. Time to pull out those tools and let the music begin!
  • Scale Length: 648mm / 25.5″
  • Striped engineered-wood guitar body, double-cutaway and contoured, with a black pickguard already fitted
  • Black pickguard assembly with three black single-coil pickups, three black numbered knobs, a blade selector switch and wiring
  • Neck with fretted rosewood fingerboard and dot inlays
  • Black tremolo bridge with six saddles and a sustain block
  • Black tremolo arm
  • Tremolo spring claw with two mounting screws
  • 3x springs
  • Black back cover plate with six string slots
  • Black rectangular back cover plate
  • Black boat-shaped jack plate with output jack fitted
  • 2x black strap buttons
Double-Cutaway Contoured Electric Guitar Kit, Engineered Zebrawood Body, Rosewood Fretboard, Black Hardware is on pre-order.
