RD2 Guitar Kit w/ Ebony Fretboard, Flamed Maple Top Veneer
SKU RD2-RMEB-1
$289.99 USD
$289.99 USD - $289.99 USD
Current price $289.99 USD
Build your own DIY guitar with a beautiful flamed maple veneer mahogany body tonewood and ebony fretboard with pearl white fretboard inlays.
  • Bolt-on neck joint bolts straight on, so there is no gluing or clamping to get right, but the flamed Maple veneer is thin and easy to sand through, so use a light touch at the edges
  • Material: Mahogany (1 pc)
  • Top Veneer: Flamed Maple
  • Material: Ebony
  • Nut: Ivory Plastic
  • Unfinished routed guitar body with a figured top
  • Neck with dark fretted fingerboard and dot inlays
  • 6x black sealed tuners with black bushings and washers
  • 2x black humbuckers with exposed pole pieces in black mounting rings
  • Pre-wired harness with two potentiometers and a toggle switch
  • Black switch tip
  • Black stop tailpiece
  • Black bridge with individually adjustable saddles
  • 2x bridge posts and 2x tailpiece studs
  • 2x black dome knobs
  • Output jack on a black oval jack plate
  • Angular black cavity cover
  • Black neck plate with 4 screws
  • 2x black washers, 2x chrome washers and 2x nuts
  • 2x black strap buttons
RD2 Guitar Kit w/ Ebony Fretboard, Flamed Maple Top Veneer is on pre-order.
