Classic Single-Cutaway Electric Guitar Kit, Mahogany Body, Engineered Rosewood Fretboard, Pre-Wired Solderless
SKU TE-RMOC-29
Original price $249.99 USD
Build your own classic single-cutaway guitar with this TE-style DIY kit. The warm mahogany body pairs with a maple neck and Rosewood (Engineered) fretboard for a rich, balanced tone. Pre-wired electronics with plug-and-play connectors make this an ideal first build, just assemble, finish, and play.
Beginner (1/10)
  • Bolt-on neck joint requires only a screwdriver to attach
  • Pre-wired electronics with plug-and-play connectors eliminate soldering
  • Mahogany's open grain benefits from grain filler before finishing
  • Material: Mahogany (2 pcs)
  • Scale Length: 648mm / 25.5"
  • Nut Width: 42mm
  • Tuner Holes: 10mm
  • Bridge Pickup: TE-Style Single Coil
  • Bridge: Hardtail
  • Knobs: Chrome Dome
  • Pre-wired control plate (1 volume, 1 tone, 3-way blade switch)
  • Neck single coil pickup (pre-wired to control plate)
  • TE-style top-loading bridge with bridge pickup and 6 barrel saddles
  • Chrome dome knobs
  • Neck plate with screws
  • Output jack with diamond plate
  • String trees
Classic Single-Cutaway Electric Guitar Kit, Mahogany Body, Engineered Rosewood Fretboard, Pre-Wired Solderless is in stock.
