SKU LP-RMPC-29
Original price $259.99 USD
Current price $219.99 USD
$219.99 USD - $219.99 USD
Beginner (3/10)
  • Nut Width: 42mm
  • Tuner Holes: 10mm
  • Knobs: Black Speed Knobs
  • 4x black speed knobs
  • Toggle switch plate
  • Strap pins
  • Neck plate and screws
