SKU LP-RMPC-29
Original price $259.99 USD
Current price $219.99 USD
$219.99 USD - $219.99 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: May 25 – Jun 1 1–2 weeks from the date of your order. Ships to U.S. addresses only. Free Shipping
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Jun 15 – Jun 29 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
  • Orientation: Right-handed
Beginner (3/10)
  • Radius: 12" / 305mm
  • Inlay Material: Black ABS
  • Shape: Blues Classic 3+3
  • Tuner Holes: 10mm
  • Nut Width: 42mm
  • Output Jack: Side-mounted
  • Bridge: Chrome Wraparound
  • Knobs: Black Speed Knobs
  • 4x black speed knobs
  • Toggle switch plate
  • Strap pins
  • Neck plate and screws
