SKU ST-RMPC-29
Original price $249.99 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Oct 8 – Oct 22 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
  • Material: Mahogany (2 pcs)
  • Scale Length: 648mm / 25.5"
  • Nut Width: 42mm
  • Tuner Holes: 10mm
  • Knobs: White Plastic
  • White plastic nut
  • String trees
  • Tremolo springs
  • Neck plate with screws
  • Output jack
  • Allen wrenches
Double-Cutaway Contoured Electric Guitar Kit, Mahogany Body, Maple Fretboard, Pre-Wired Electronics is in stock.
