SKU BLK-WB-A
Original price $269.99 USD
Current price $219.99 USD
$219.99 USD - $219.99 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Oct 12 – Oct 26 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
  • Number of Strings: 4
  • Scale Length: 864 mm / 34"
  • Radius: 12" / 305mm
  • Number of Frets: 24
  • Shape: Blank (Not Drilled)
  • Pickups: PJ-style Bass
  • Bridge: Fixed
  • Cavity Covers: White
  • Black bar-style bass pickup
  • 3x chrome dome knobs
  • 3x pot nuts and 3x washers
  • White teardrop pickguard
  • Coiled bass string set
  • Assorted screws
