Builders ask us all the time: "What is the best way to get a custom guitar?" The honest answer is that it depends on your budget, your patience, and whether you want to hold a soldering iron. We have helped over 5,000 people build their own custom instruments from kits, and we have seen the results of every other path too. Here is the complete picture.
A custom guitar is any instrument built or modified to the owner's personal specifications: body shape, tonewood, finish, neck profile, pickups, and hardware chosen by the player rather than selected by a factory. Four paths lead to a custom guitar, each trading off cost, time, skill, and creative control differently. This guide covers every option so you can pick the path that fits your goals and budget.
Whether you want a weekend project for under 300 USD or a handcrafted instrument from a master luthier, there is a proven route to the custom guitar you are imagining. The differences come down to how much of the work you want to do yourself, how much you want to spend, and how long you are willing to wait.
The Four Paths to a Custom Guitar
DIY Guitar Kit
Cost Range: 190 to 450 USD
Time Investment: 15 to 40 hours
Skill Required: Beginner-friendly
Customization Level: High
Parts Build
Cost Range: 400 to 1,200 USD
Time Investment: 20 to 60 hours
Skill Required: Intermediate
Customization Level: Very high
Luthier Commission
Cost Range: 1,500 to 5,000 USD
Time Investment: 3 to 12 month wait
Skill Required: None
Customization Level: Full
Brand Custom Shop
Cost Range: 3,000 to 10,000+ USD
Time Investment: 6 to 18 month wait
Customization Level: High (within brand options)
Each path produces a genuinely custom instrument. The right choice depends on your priorities. Read on for the honest breakdown of each option, or jump straight to the cost comparison for detailed pricing.
Path 1: DIY Guitar Kits - Build It Yourself
A DIY guitar kit is a complete building package: pre-shaped body, pre-profiled neck, hardware, pickups, wiring, and step-by-step assembly instructions. You supply the finish and basic tools. The guitar you build is genuinely custom because you control the finish, the setup, and any component upgrades you choose to make.
Built by a Guitar Kit World community member.
Why builders choose this path:
Lowest cost. GKW kits start at 189.99 USD. Total all-in cost (kit + finishing supplies + strings) runs 250 to 500 USD for most builds.
Hands-on experience. You learn how every part of a guitar works by putting it together yourself. That knowledge makes you a better player and saves money on future maintenance and repairs.
Complete creative freedom on finishing. Sunburst, solid color, natural grain, epoxy art, hand-painted designs, a bare wood kit is a blank canvas.
No wait time. In-stock kits ship immediately. You start building when the box arrives.
What to expect:
Assembly takes 4 to 6 hours for an experienced builder. Finishing (sanding, staining or painting, clear coating, curing) accounts for 60% or more of total build time. Most first-time builders complete their guitar over 2 to 4 weekends.
Every GKW kit includes a body, neck, tuning machines, bridge, pickups, electronics, all mounting hardware, and an assembly manual. The kits span every major body style: S-style, T-style, single cutaway, double cutaway, semi-hollow, hollow body, bass, baritone, 7-string, 8-string, headless, and more.
Best for: hobbyists, tinkerers, parents building with kids, players who want to understand their instrument, anyone who enjoys making things with their hands.
A parts build means buying each component individually from different suppliers: body from one source, neck from another, pickups from a third, hardware from a fourth. You assemble everything yourself.
Maximum control. You pick the exact body shape, wood species, neck profile, fret size, pickup brand and model, bridge type, and every piece of hardware. Nothing is pre-selected for you.
Specific aftermarket components. If you have a particular set of pickups or a specific bridge in mind, a parts build lets you build around those components.
The trade-offs:
Higher cost. Buying individually eliminates bundle pricing. A parts build typically costs 400 to 1,200 USD before finishing supplies, often 2 to 3 times what a comparable kit would cost.
Compatibility risk. Neck pockets, bridge routing, pickup cavities, and hardware mounting holes must all match. Sourcing from multiple vendors means verifying fitment yourself.
More experience required. Parts builds assume you already know how guitar components work together. This is not the best path for a first build.
Best for: experienced builders who know exactly which aftermarket components they want and have the skills to source and fit them.
If a parts build appeals to you but this is your first project, consider starting with a kit build and upgrading components later. You get the learning experience of a full build with the safety net of pre-matched components.
Path 3: Luthier Commission - Handcrafted to Your Specs
A luthier is a skilled craftsperson who builds and repairs stringed instruments by hand, typically working from a private workshop. Commissioning a luthier means you specify every detail: scale length, body shape, tonewood, neck carve, finish, pickups, and hardware. The luthier does all the work.
Why players choose this path:
Zero hands-on work required. You describe what you want. A professional builds it.
Expert craftsmanship. A skilled luthier selects and matches woods, carves custom neck profiles, and applies finishes at a level most amateur builders cannot match.
True one-on-one collaboration. You work directly with the person building your instrument, adjusting specs as the build progresses.
What you are paying for:
Hand-selected tonewoods matched for grain, weight, and resonance
Custom neck carving to your exact hand measurements
Professional-grade finishing (nitrocellulose, French polish, specialty finishes)
Full setup and playability optimization
A relationship with the builder who knows your guitar inside and out
The trade-offs:
1,500 to 5,000 USD. The luthier's time, skill, and materials are the cost drivers. Established builders with long backlogs charge at the higher end.
3 to 12 month wait. Most independent luthiers have a queue. Some well-known builders have 2+ year wait lists.
No brand resale cachet. A luthier-built guitar plays and sounds excellent, but the secondhand market values brand recognition over individual craftsmanship.
Best for: players who want full customization with zero effort, those who value master craftsmanship, and professionals who need an instrument built to specific performance requirements.
The major guitar manufacturers run custom shop programs where you configure an instrument within their platform's options. You choose from approved body shapes, wood combinations, finishes, and hardware. The factory builds it to your order.
Brand name and resale value. Custom shop instruments from recognized brands hold their value on the secondhand market. This is the single biggest differentiator from the other three paths.
Factory consistency. Custom shop builds go through the same quality control as production models, with tighter tolerances and premium materials.
Warranty and support. Brand-backed warranty, authorized service network, and documented provenance.
The trade-offs:
3,000 to 10,000+ USD. You are paying significantly for the brand, the factory infrastructure, and the warranty. The raw materials and components in a 5,000 USD custom shop guitar are comparable to what goes into a 400 USD kit build.
6 to 18 month wait. Factory queues are long.
Limited options. You choose from the brand's approved menu of shapes, woods, finishes, and hardware. Truly novel designs (custom body shapes, non-standard scale lengths, unusual pickup configurations) are either impossible or carry massive upcharges.
Best for: collectors, players who specifically want a branded instrument, and those who prioritize resale value and warranty.
How to Design Your Custom Guitar
Regardless of which path you choose, the design decisions are the same. Here is what you need to decide, in order of impact:
1. Body Shape and Style
The body shape determines how the guitar looks, balances on a strap, and accesses upper frets. Choose based on the music you play and the ergonomics you prefer.
Double cutaway (S-style, offset): best upper fret access, most versatile
Single cutaway: classic look, slightly more body mass and sustain
Semi-hollow or hollow body: warmer acoustic resonance, lighter weight
Specialty shapes (V, angular, headless): distinctive looks and ergonomics
The neck is where your hand lives. Choose based on hand size and playing style. Our guide on neck profiles and hand sizes matches profiles to player types.
The finish is your biggest creative opportunity. Options range from a simple oil wipe (20 USD, one afternoon) to a multi-stage sunburst with hand-rubbed lacquer (100+ USD, several weekends).
Our guitar finishing 101 guide covers every method from beginner-friendly oils to professional spray techniques.
Real Builders, Real Guitars
The best proof that custom guitars are achievable comes from people who have done it.
Scott's first build. Zero experience. Built an S-style kit over three weekends. His takeaway: the pride of playing something he made himself was worth every hour of sanding. Read Scott's build story.
Bill's bass project. A bassist who wanted to understand his instrument from the inside out. The build taught him more about tone and setup than years of playing. See Bill's bass build.
Jason's epoxy guitar. An artistic builder who used epoxy resin to create a one-of-a-kind visual effect that no factory or custom shop would ever produce. Check out Jason's build.
Every one of these builders started with a kit from Guitar Kit World. None had professional building experience before their first project.
Which Path Should You Choose?
Choose a DIY kit if you enjoy making things, want the most value for your money, and want to learn how your guitar works from the inside out. This is the fastest, most affordable, and most educational path to a custom guitar.
Choose a parts build if you already have building experience and know exactly which aftermarket components you want. Be ready to spend 2 to 3 times what a kit costs.
Choose a luthier if you want a handcrafted, fully custom instrument without doing any of the work yourself. Budget 1,500 to 5,000 USD and 3 to 12 months.
Choose a custom shop if brand name and resale value are top priorities. Budget 3,000 to 10,000+ USD and 6 to 18 months.
For most people reading this guide, a DIY guitar kit is the right starting point. It is affordable, rewarding, and produces a genuinely custom instrument. You can always upgrade later or commission a luthier for your second guitar once you know exactly what you want.
Guitar Kit World is a US-based retailer specializing in DIY electric and bass guitar kits, offering 288+ kits with step-by-step assembly manuals and expert build support since 2013. Browse the full catalog or start with a beginner-friendly kit.
What is the cheapest way to get a custom guitar?
A DIY guitar kit is the most affordable path. GKW kits start at 189.99 USD. Add 50 to 150 USD for finishing supplies and tools, and you have a complete custom guitar for 250 to 500 USD total. For detailed pricing across all four paths, read our custom guitar cost guide.
Can a beginner build a custom guitar?
Yes. DIY guitar kits are designed for all skill levels. Beginner-rated kits include pre-shaped bodies, pre-drilled holes, and step-by-step manuals. No woodworking or luthiery experience is needed. Read our beginner guide for a full walkthrough.
How long does it take to build a custom guitar from a kit?
Most builders spend 15 to 40 hours, depending on the finish complexity. Assembly itself takes 4 to 6 hours. Finishing (sanding, painting, clear coating) accounts for most of the time because each coat needs drying time.
Are custom guitars worth it?
For players who value personalization and the building experience, yes. A DIY kit delivers a one-of-a-kind instrument for under 500 USD. For the full breakdown, read are custom guitars worth it.
What is the difference between a guitar kit and a parts build?
A kit includes all components from a single manufacturer, pre-matched for compatibility. A parts build means sourcing each component individually. Kits are simpler, more affordable, and better for beginners. Parts builds offer maximum component control but cost 2 to 3 times more and require experience to ensure compatibility.
Do DIY guitar kits sound good?
Yes. Sound quality depends on the pickups, wood, and setup, not on where the guitar was assembled. A properly set up kit guitar with quality components sounds equal to a factory instrument at the same component level.
GKW offers a Custom Shop where you can select body style, wood, pickups, hardware, and other options to configure a guitar to your specifications. The kit ships with all your chosen components ready for assembly.
