There’s an endless list of choices available when it comes to guitar finishing. Options include oiling, staining, finishing in a graduated combination of colors e.g. sunburst to a standard solid color finish.
Guitar Finish Types
Recommended: DIY Guitar Finishes: How to Choose the Right Finish for Your Guitar Kit
Basswood
Basswood
Paulownia
Paulownia
Alder
Alder
Ash
Ash
Mahogany
Mahogany
Flamed Maple
Flamed Maple
Quilted Maple
Quilted Maple
Spalted Maple
Spalted Maple
    Take The DIY Guitar Quiz
    Guitar Finishing Materials
    Ventilation mask
    ventilation mask for painting
    This should always be your first port of call if finishing a guitar, fumes have the potential to make you sick and in severe cases have caused brain damage. While you should wear it for both sanding and finishing, we recommend you purchase a ventilation mask suitable for painting. Remember finishing supply fumes are no joke, please read our article on guitar finishing safety before proceeding you are unaware of the potential risks.
    Sandpaper
    (View on Amazon)
    Painters tape
    Painters tape
    (View on Amazon)
    Sealed Plastic Containers
    sealed plastic containers
    Tinted Grain Filler
    (View on Amazon)
    Stain
    stain
    (View on Amazon)
    Clear Coat - Wax or Oil
    (View on Amazon)
    (View on Amazon)
    Recommended: Luthier Tools for DIY Guitar Kits
    Guitar Finishing Step-by-Step
    Step 2: Final Sanding
    Final sanding
    Your next step should be to sand the guitar. Look for any scratch marks left from the factory and sand until these are removed. If the marks are deep and require a low grit sandpaper you will need to work your way up to at least a 450 grit sandpaper once the scratch is no longer visible as each grade of sandpaper will leave scratch marks that must be removed with each higher grade of sandpaper applied.
    Finishing Tips for Veneered Kits
    If your kit includes a veneer top (like flamed, spalted, or quilted maple), it’s important to take extra care during prep and finishing. Veneers are made from real wood and often have thin, delicate layers that are easy to damage if not handled carefully.
    ⚠️ Note: These veneers are natural wood, not synthetic or printed. It’s common to see minor imperfections or distressed sections—this is part of their character. Handle with care to preserve their beauty.
    DO:
    • Inspect the veneer under good lighting for glue spots, blemishes, or imperfections that may resist stain.
    • Sand very lightly by hand using 400 grit sandpaper. Just a few passes to smooth it—no pressure.
    • Use a clean sanding block or sponge (no power tools!) to avoid burning through the thin veneer.
    • Raise the grain by wiping gently with a damp cloth and then lightly sanding again with 400 grit.
    • Consider masking edges or fragile spots if they look thin or distressed.
    DON’T:
    • Don’t use coarse sandpaper (nothing under 400 grit).
    • Don’t use a power sander or press down while sanding—veneers are thin and easy to sand through.
    • Don’t overdo grain filling—most veneered tops don’t need it and some fillers can muddy the figure.
    Best Finish Options For Kits With Veneer Tops
    • Stain or Dye to highlight the wood grain figure (flame/quilt).
    • Translucent or clear coats like shellac or poly to preserve the pattern.
    • Oil finishes like Tru-Oil also work well if applied in thin layers and gently buffed.
    To learn more about finishing types we recommend reading the following guide: DIY Guitar Finishes: How to Choose the Right Finish for Your Guitar Kit.
    Step 3: Final Clean
    Step 4: Masking
    To ensure a flawless finish, take the time to tape off any areas of your guitar, such as the neck pocket, pickup holes and fretboard that don't need finishing.
    Ebony tinted grain filler
    (View on Amazon)
    Now that the guitar is ready to apply your finish it’s time to use either your tinted grain filler or dark stain to highlight the grain of the timber. You can read more about mixing grain filler here. It’s always best to test your mix on a spare piece of timber first if available and then simply apply the product and wait for it to dry.
    Step 6: Re-Sanding
    sanded - highlighted grain
    Step 7: Staining
    Stain Finish
    (View on Amazon)
    • Follow the manufacturer’s recommendations for mixing.
    • If your guitar has a veneer maple top e.g. most LP-style Guitar kits come with a thin maple veneer you will need to be careful to only apply the stain very lightly. If you saturate the veneer it can start to bubble which will result in the veneer being required to be completely removed and requiring you to perform many of the steps listed above over again.
    • Always use a clean rag. While it may seem obvious that using a rag that has been used for other purposes previously is a bad idea e.g. I have known of a signwriter who mistook a clean rag for a previously used rag that had been exposed to paint thinners and caused a number of problems.
    • Your hand should be constantly moving to achieve an even finish. If you use inconsistent hand movements it is likely that your stain will look heavier in some section than others which should be avoided at all costs.
    Stain ball cloth
    Step 8: Scraping the Binding
    Scraping the binding
    Highlighted grain and stain guitar finish
    Step 10: Final Sanding
    Step 11: Polishing
    Related Products
    Ready to Ship
    🌍 Worldwide
    Ash ST-style guitar kit with Pau Ferro fretboard Maple Neck
    Original price $239.99 USD
    Build Skill 4/10 — Beginner
    Start your dream guitar build with this ash ST-style kit, complete with Pau Ferro fretboard maple neck for a beautiful finish. Perfect for aspiring...
    Ready to Ship
    🇺🇸 US Only
    JE Style Guitar Kit with Monkey Grip and Tree of Life Fretboard Inlay
    Current price $229.99 USD
    $229.99 USD - $229.99 USD
    Build Skill 5/10 — Intermediate
    JE style 6-string guitar kit with a solid basswood body, skunk striped maple neck, and a beautiful rosewood fretboard. Specifications Hand Orienta...
    Pre-Order
    🌍 Worldwide
    Basswood ST style guitar kit with Maple Neck and Fretboard, Chrome Hardware
    Original price $249.99 USD
    Current price $189.99 USD
    $189.99 USD - $189.99 USD
    Build Skill 2/10 — Beginner
    Build your own Basswood ST style guitar with Maple Neck and Fretboard, Chrome Hardware. You can find ST-style guitar building instructions here: ...
    Ready to Ship
    🌍 Worldwide
    Original price $269.99 USD
    Build Skill 8/10 — Advanced
    Ready to Ship
    🌍 Worldwide
    Blank ST-style Mahogany Body Guitar kit w/ Rosewood Fretboard
    Original price $229.99 USD
    Build your own classic ST-style guitar with this blank body DIY kit, crafted for players who want full control over shaping, finishing, and tone. F...
    Ready to Ship
    🌍 Worldwide
    Blank TE-style Guitar Kit w/ Rosewood Fretboard
    Build a classic tone machine from the ground up with this blank TE-style guitar kit. Designed for makers who want full shaping, finishing, and tona...
