A well ventilated work area
1. Preparation and Finishing
2. Hardware Installation
Step 1: Preparation & Finishing
Mock install the neck to check neck fit. Align it in the pocket and ensure it’s straight and snug. Use a steel ruler to measure from the nut to the 12th fret, then double that distance. This is your scale length (~25.5”). Mark the centerline and bridge position — center should fall between string holes 3 & 4 on the bridge.
Steps:
Measure from the nut to the center of the 12th fret.
Double that distance — this is your scale length (typically ~25.5”).
Align the bridge’s center (between string holes #3 and #4) with this measurement.
See reference image for visual guide.
Use the dot inlay on the neck as a vertical guide for bridge centerline alignment.
Push the neck into the pocket and ensure snug fit.
Headstock Shaping (Optional – Do This Before Finishing)
If your kit comes with a blank headstock, you can create your own custom shape.
Sketch your design on paper first, then trace it onto the headstock.
Cut the shape using a coping saw, jigsaw, or bandsaw.
Sand the edges smooth and leave at least 15mm of wood around each tuner hole
Once shaped, move on to sanding and finishing the neck.
Finishing
Before starting, it’s important to properly sand, clean, and finish your guitar body and neck.
This section walks you through installing the hardware after your finish is fully cured.
a. Installing the Neck
Place the neck into the pocket and confirm a snug, centered fit.
Check scale length: Measure from the nut to 12th fret, then double that distance — this is where the center of the saddle should land (between string holes #3 and #4).
Use a steel ruler to align the saddle with the 12th fret dot inlay.
When you’re confident in the alignment, screw the neck into place using the neck plate, screws, and cushion.
b. Installing Tuners
Insert each tuner into the back of the headstock.
Add washers and bushings, then tighten nuts by hand.
Align the tuners (use a steel ruler across the top).
Mark pilot holes, pre-drill, and install screws.
c. Installing the Bridge & Piezo Pickup
Align the bridge placement using scale length measurements.
Route the piezo pickup wire through the pre-drilled hole into the body cavity.
Once aligned, mark pilot holes for the bridge and install it using screws provided.
Do not overtighten, as this can crack the finish or damage the top.
d. Installing the Strap Buttons
Rear button goes at the center of the lower bout.
Front strap button can go on the upper horn or neck heel, based on your preference.
Mark pilot holes, drill carefully, and screw in.
f. Installing the Equalizer Panel
Align the equalizer control panel with the routed cavity.
Carefully route all wires through as shown in the wiring diagram (covered in Section C above).
Screw in the panel using small screws supplied.
3. Installing the Electronics
Your kit features a Piezo Pickup + Master Volume + 4-Band Equalizer system. Good news — the system is pre-wired and plug-and-play, so there’s no soldering needed.
Components Overview:
Piezo Pickup – mounted under the saddle.
4-Band EQ Module – includes Volume and EQ sliders.
Output Jack – connects your guitar to an amplifier.
9V Battery Compartment – powers the preamp/EQ.
Wiring Diagram:
Refer to the image below or download PDF wiring diagram here: Wiring Diagram (PDF)
Installation Steps:
1. Mount the EQ module on the side of the body.
Fit the EQ module into the side cavity.
Secure with screws provided.
Do not overtighten — this can crack the finish.
2. Insert the 9V Battery
Place inside the compartment.
Test fit now to ensure easy battery access later.
3. Connect the piezo wire to the EQ input.
Thread the piezo pickup wire through the pre-drilled hole from the bridge to inside the body.
Plug it into the labeled Piezo Input Jack on the EQ module.
4. Attach the volume knob and confirm it’s wired to EQ output.
Mount the jack securely into its routed cavity.
Connect the EQ module’s output wire to the jack (already attached in most kits).
5. Test by plugging into an amp and adjusting EQ sliders.
Plug the guitar into an amp.
Lightly tap the saddle area and adjust EQ sliders.
If you hear sound, you’re good to go.
No soldering required — plug-and-play.
EQ won’t work unless a 9V battery is installed and a cable is plugged into the output jack (activates circuit).
4. Final Assembly & Setup
Once your hardware and electronics are installed, it’s time to fine-tune your guitar for playability and tone. This includes adjusting the neck, string height, and intonation.
Install Your Strings
Use a fresh set of acoustic guitar strings.
Install them one at a time, threading through the bridge and tuners.
Tune to concert pitch (E A D G B E) before proceeding.
Adjust the Neck Relief
You may not need to make any adjustments, but if needed:
Use the included hex key to access the truss rod at the headstock.
To add relief (loosen truss rod): turn counter-clockwise.
To flatten neck (tighten truss rod): turn clockwise.
Only adjust 1/8–1/4 turn at a time, then retune and re-check.
Hold down the first and last fret and tap around the 7th–9th fret. You should see a slight gap (~0.25mm). No gap = too flat.
Check and Adjust String Action
“Action” refers to string height above the fretboard:
Measure string height at the 12th fret using a ruler or feeler gauge.
A good starting point:
Low E (6th string): ~2.5mm
High E (1st string): ~2.0mm
If action feels too high, you can sand the bottom of the saddle slightly to lower it.
Be sure to sand evenly and test often. Removing too much will make it buzz.
Intonation Check (Acoustic)
Acoustic guitars don’t have adjustable saddles like electrics, but you can still:
Check 12th fret note vs. harmonic.
If notes are consistently sharp or flat, reposition the saddle slightly or check if it’s fully seated in the slot.
For significant intonation issues, consult a tech or luthier.
Electronics Test
Once strings are on and tuned:
Plug into an acoustic amp.
Tap on the saddle to confirm piezo pickup works.
Test the volume and all 4 EQ bands (Low, Mid, High, Presence).
Check for unwanted hum, buzz, or cutouts.
Troubleshooting
No sound output?
Check battery and cable connection. Ensure piezo is seated flat under saddle.
Strings buzzing or action too high?
Adjust truss rod or lower the saddle.
Bridge placement feels wrong?
Re-check your 12th fret measurement and centerline.
As a longtime contributor at Guitar Kit World, Nathan has spent more than a decade helping guitar builders turn basic kits into stage-ready instruments...
We are excited to highlight an upcoming Intro to Electric Guitar Building Workshop led by builder and instructor Kalimar Maia (@mar_mar_guitars) at Nova Labs in Fairfax, Virginia (@nova_labs). Images courtesy of Kalimar Maia This small-group, hands-on workshop is designed for...
When Jim Larsen set out to build a bass guitar, his goal was not just another instrument. He wanted to thank a friend. Bill Adam is a retired Air Force pilot and longtime musician. Jim decided the best way to...
Sometimes during your DIY build, you’ll decide to swap out a bridge, maybe to upgrade to higher quality hardware, or just because your first choice didn’t feel right. The good news is, plugging and redrilling bridge holes is a straightforward...
