Contact Pickups (essentially microphones)
Piezo Pickups (Which use crystals and don’t pick up outside interference as a result. They also sound fantastic)
Active Pickups (Which require a source of electricity such as a battery)
Magnetic Pickups Explained
Humbuckers as the name might suggest ‘buck’ this unwanted hum by creating two separate signals that essentially cancel each other out. Because they are less affected by unwanted frequencies by nature and use a much larger magnet they tend to be better suited to higher output. This is the reason you will see humbuckers used in metal and heavy rock.
What Does This Mean To You?
Where Does Tone Come From?
Need a wiring diagram for your build? Browse every kit and pickup combo in our community: Find your wiring diagram →
Some builders read the manual once and wing it. Others spend years learning why the manual says what it says. Jamie Mangrum is firmly the second kind, and that is exactly why we wanted to talk to him. Jamie is...
Ten SAU students turned blank guitar kits into playable, personal electric guitars, then played them live at the class's second annual exhibit and jam.
Here at Guitar Kit World, we appreciate the creativity of our DIY community. Every once in a while, a build stands out. That’s exactly what happened when we saw the recent work of Norway-based artist and musician, Peter-John de Villiers...
