SKU L3-RPRB-4831
Current price $269.99 USD
$269.99 USD - $269.99 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Sep 11 – Sep 18 1–2 weeks from the date of your order. Ships to U.S. addresses only. Free Shipping
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Oct 2 – Oct 16 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
Build your own classic blues inspired thin hollow body guitar. Featuring a maple plywood body with maple center block, set-in mahogany neck, Ebony (Engineered) fretboard, and dual humbuckers for warm tone and dynamic response. Ideal for players seeking vintage character with modern reliability.
  • Maple Plywood is a closed-grain wood, so no grain filling is needed before finishing
  • Material: Maple Plywood
  • Upper Bout: 310mm
  • Waist: 248mm
  • Lower Bout: 415mm
  • Depth: 43.5mm
  • Scale Length: 24.75 inch (628mm)
  • Nut: Ivory Plastic (ABS)
  • Bridge: Tune-O-Matic W/ Stopbar
  • Knobs: Black Plastic
  • Neck with dark fingerboard, dot position markers, ivory binding and a drilled headstock
  • 1x large black pickguard
  • 1x black switch washer ring
  • 4x black knurled knobs
