Mahogany G1 Guitar Kit w/ Rosewood Fretboard, Pre-wired Electronics
SKU G1-RMRC-512
Original price $259.99 USD
Current price $229.99 USD
$229.99 USD - $229.99 USD
G1 DIY guitar kit featuring a mahogany body with a classic double-cutaway design, a mahogany neck, and a rosewood fretboard with trapezoid inlays. This kit includes pre-wired electronics with 2 humbuckers and a complete wiring harness - no soldering required.
  • Orientation: Right-handed
Beginner (2/10)
  • Bolt-on neck joint requires only a screwdriver for attachment
  • Pre-wired electronics eliminate all soldering - just plug in the pickups and connect
  • Radius: 12"
  • Shape: Blues Classic 3+3
  • Tuner Holes: 10mm
  • Nut Width: 42mm
  • Output Jack: Top-mounted
  • Bridge: Tune-o-Matic
  • Tailpiece: Stop Bar
  • Knobs: Black Speed Knobs
  • Pre-wired electronics harness (2 humbucker pickups, 2 volume pots, 2 tone pots, 3-way toggle switch, output jack - all wired and ready to install)
  • Tune-o-Matic bridge
  • Stop bar tailpiece
  • 4x black speed knobs
  • 2x black cavity covers
  • Neck plate and screws
Mahogany G1 Guitar Kit w/ Rosewood Fretboard, Pre-wired Electronics is on pre-order.
