Mahogany ST-style Guitar Kit with Maple Fretboard, Pre-wired Electronics
SKU ST-RMPC-29
Original price $229.99 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Jun 20 – Jun 27 1–2 weeks from the date of your order. Ships to U.S. addresses only. Free Shipping
  • Orientation: Right-hand
  • Scale Length: 648mm / 25.5"
Beginner (1/10)
  • Material: Mahogany (2 pcs)
  • Material: Maple (2 pcs)
  • Radius: 12"
  • Inlay Material: Black (ABS)
  • Shape: S-style 6-in-line
  • Tuner Holes: 10mm
  • Nut Width: 42mm
  • Knobs: White Plastic
  • White plastic nut
  • String trees
  • Tremolo springs
  • Neck plate with screws
  • Output jack
  • Allen wrenches
Mahogany ST-style Guitar Kit with Maple Fretboard, Pre-wired Electronics is in stock.
