Acoustic-Electric Thin Semi-Hollow Single-Cutaway Guitar Kit, Basswood Body, Flame Maple Veneer, Piezo Pickup
SKU TEH-RBRC-3652
Original price $279.99 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Sep 17 – Oct 1 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
Build your own acoustic electric guitar with this TE-style semi-hollow DIY kit, designed to deliver warm acoustic resonance with added clarity and control when plugged in. Featuring a semi-hollow body with a center block, this kit balances natural acoustic tone with improved sustain and reduced feedback, making it ideal for both stage and studio use.
  • Orientation: Right-handed
  • Scale Length: 648mm / 25.5"
Intermediate (5/10)
  • The wooden bridge is glued in place and its position sets the intonation, so careful measuring matters
  • Type: Semi-Hollow with Center Block
  • Top Veneer: Flamed Maple
  • Body Binding: Ivory
  • Shape: Blank, 6-in-line (ready for full customization)
  • Nut Width: 42mm
No soldering required. The complete electronics system arrives pre-wired, and every connection is a plug-in connector.
  • Piezo pickup sits under the bridge saddle and plugs straight into the preamp input.
  • Side-mounted preamp with master volume and 4-band EQ gives you control over lows, mids, highs, and presence.
  • Output jack arrives already wired to the harness.
  • Powered by a 9-volt battery (not included). The EQ works only when a battery is installed and a cable is plugged into the output jack.
  • To install, you mount the parts, connect the labeled plugs, and test.
  • Soldering Required: None (Fully Pre-Wired)
See the full step-by-step walkthrough with photos: How to Build an Acoustic-Electric Guitar Kit with Onboard EQ.
  • Bridge: Wooden Acoustic-Style with Pins
  • Tuners: Closed, Chrome
  • Knobs: Black Plastic
  • Hardware Finish: Chrome
  • Truss Rod: 2-Way Adjustable
  • Semi-hollow basswood body with flamed maple veneer and ivory binding (unfinished)
  • Piezo pickup
  • Wooden acoustic-style bridge with pins and saddle
  • Neck plate with screws
  • Strap buttons with screws
  • Allen wrenches
  • Set of strings
  • 1/4" instrument cable
Acoustic-Electric Thin Semi-Hollow Single-Cutaway Guitar Kit, Basswood Body, Flame Maple Veneer, Piezo Pickup is in stock.
