How to wire a 3 single coil, 1 vol, 1 tone, 5-way selector guitar
In this article, we will walk you through the process of wiring a guitar with 3 single coil pickups, 1 volume, 1 tone, and 5 way switch. Wiring a guitar is not that difficult if you know what to do and have the right resources to refer to. This guitar wiring diagram is common in most Stratocasters and I have included a wiring diagram of a stratocaster below.
Source: https://guitarelectronics.com/guitar-wiring-resources/
Do you want to learn more on how guitar electronics works? Check out this article explaining how guitars work
Take The Quiz
Neck Profiles for Large & Small Hands: U-shaped, V-shaped, C-shaped, Flat C-shaped
A closer look at U-shaped, V-shaped, C-shaped, Flat C-shaped Neck Profiles. While variety is most...
Scott’s First DIY Guitar Build
Building a guitar is more than just assembling wood and hardware. It’s a chance to create somethi...
The Art and Heart of Ken Pfalzgraf’s Guitars
Step into Ken Pfalzgraf’s workshop — better known online as Paul Mero Junkpile Guitars — and you’...
