How Does Pickup Position Affect Sound? | Guitar Kit World Skip to content
Types of pickups
Pickup positions
The neck position
The middle position
The bridge position
Playability
Previous article How do you fix the guitar binding?
Next article How to check the neck alignment and neck angle
